Hallo, mein Apache stürzt alle 5 - 7 Tage immer ab.
Im Anhang hab ich die Log Dateien.
Hab SuSE 10.1 und Plesk 8.3.
ps aux
cat /proc/user_beancounters
Ich hoffe mir kann jemand helfen.
mfg
druckgott
ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 640 284 ? Ss 19:43 0:00 init [3]
root 28538 0.0 0.0 2192 612 ? S<s 19:43 0:00 /sbin/udevd --daemon
100 29782 0.0 0.0 3360 912 ? Ss 19:43 0:00 /usr/bin/dbus-daemon --system
root 29861 0.0 0.0 3140 1588 ? Ss 19:43 0:00 /usr/sbin/hald --daemon=yes --retain-privileges
root 30145 0.0 0.0 1516 624 ? Ss 19:43 0:00 /sbin/syslogd -a /var/lib/named/dev/log
root 30165 0.0 0.0 2976 752 ? S 19:43 0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrlogge
root 30167 0.0 0.0 2880 840 ? S 19:43 0:00 /usr/sbin/courierlogger imapd
root 30178 0.0 0.0 2976 752 ? S 19:43 0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrlogge
root 30185 0.0 0.0 2976 752 ? S 19:43 0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrlogge
root 30187 0.0 0.0 2880 840 ? S 19:43 0:00 /usr/sbin/courierlogger imapd-ssl
root 30196 0.0 0.0 2880 840 ? S 19:43 0:00 /usr/sbin/courierlogger pop3d
root 30197 0.0 0.0 2972 748 ? S 19:43 0:00 /usr/lib/courier-imap/couriertcpd -address=0 -stderrlogger=/usr/sbin/courierlogger -stderrlogge
root 30199 0.0 0.0 2880 840 ? S 19:43 0:00 /usr/sbin/courierlogger pop3d-ssl
root 30208 0.0 0.0 4860 1168 ? Ss 19:43 0:00 /usr/sbin/sshd -o PidFile=/var/run/sshd.init.pid
root 30214 0.0 0.0 2148 872 ? Ss 19:43 0:00 /usr/sbin/xinetd
named 30286 0.0 0.1 36720 2852 ? Ssl 19:43 0:00 /usr/sbin/named -t /var/lib/named -u named
root 30309 0.0 0.0 2452 1200 ? S 19:43 0:00 /bin/sh /usr/bin/mysqld_safe --user=mysql --pid-file=/var/lib/mysql/mysqld.pid --socket=/var/li
mysql 30358 0.1 0.7 115508 14908 ? Sl 19:43 0:02 /usr/sbin/mysqld --basedir=/usr --datadir=/var/lib/mysql --user=mysql --pid-file=/var/lib/mysql
qmails 30380 0.0 0.0 1488 400 ? S 19:43 0:00 qmail-send
qmaill 30382 0.0 0.0 1440 452 ? S 19:43 0:00 splogger qmail
root 30383 0.0 0.0 1468 340 ? S 19:43 0:00 qmail-lspawn | /usr/bin/deliverquota ./Maildir
qmailr 30384 0.0 0.0 1464 372 ? S 19:43 0:00 qmail-rspawn
qmailq 30385 0.0 0.0 1436 340 ? S 19:43 0:00 qmail-clean
root 30416 0.0 1.2 27068 24960 ? Ss 19:43 0:00 /usr/sbin/spamd --username=popuser --daemonize --nouser-config --helper-home-dir=/var/qmail --m
popuser 30425 0.0 1.1 27068 23708 ? S 19:43 0:00 spamd child
root 30471 0.0 0.8 66072 17676 ? Ss 19:43 0:00 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf -DSSL
wwwrun 30483 0.1 1.3 80260 27968 ? S 19:43 0:01 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf -DSSL
wwwrun 30500 0.2 1.3 80136 27820 ? S 19:43 0:03 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf -DSSL
root 30530 0.0 0.3 39860 6624 ? Ss 19:43 0:00 /usr/local/psa/admin/bin/httpsd
psaadm 30534 0.0 0.5 41048 11464 ? S 19:43 0:00 /usr/local/psa/admin/bin/httpsd
wwwrun 30591 0.1 1.3 80132 27816 ? S 19:43 0:01 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf -DSSL
root 30615 0.0 0.0 1732 696 ? Ss 19:43 0:00 /usr/sbin/cron
root 30626 0.0 0.3 20276 7724 ? Ss 19:43 0:00 /usr/local/psa/admin/bin/php /usr/local/psa/admin/bin/modules/watchdog/wdcollect -c /usr/local/
root 30627 0.0 0.1 24360 2332 ? Ssl 19:43 0:00 /usr/local/psa/admin/bin/modules/watchdog/monit -Ic /usr/local/psa/etc/modules/watchdog/monitrc
psaadm 30634 0.0 0.5 41060 10548 ? S 19:43 0:00 /usr/local/psa/admin/bin/httpsd
drweb 30701 0.0 0.8 21860 18016 ? Ss 19:43 0:00 /opt/drweb/drwebd -ini=/etc/drweb/drweb32.ini
wwwrun 32141 0.0 1.3 80160 27840 ? S 19:44 0:01 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf -DSSL
wwwrun 32142 0.1 1.3 79508 27216 ? S 19:44 0:02 /usr/sbin/httpd2-prefork -f /etc/apache2/httpd.conf -DSSL
root 30312 0.0 0.1 9372 2612 ? Ss 20:12 0:00 sshd: mfcrootlogin [priv]
10003 30346 0.0 0.0 9348 1708 ? S 20:12 0:00 sshd: mfcrootlogin@pts/0
10003 30349 0.1 0.0 4492 2032 pts/0 Ss 20:12 0:00 -bash
root 30415 0.7 0.0 6400 1868 pts/0 S 20:12 0:00 su
root 30424 0.0 0.0 3968 1940 pts/0 S 20:12 0:00 bash
root 30554 0.0 0.0 2344 960 pts/0 R+ 20:12 0:00 ps aux
Version: 2.5
uid resource held maxheld barrier limit failcnt
1222138: kmemsize 5480356 5532276 8512433 9823665 1
lockedpages 0 0 3800 4096 0
privvmpages 101247 101400 138256 202568 249303
shmpages 14438 14438 131072 131072 0
dummy 0 0 0 0 0
numproc 59 61 232 232 0
physpages 45745 45745 0 2147483647 0
vmguarpages 0 0 66400 2147483647 0
oomguarpages 45745 45745 66400 2147483647 0
numtcpsock 23 23 500 500 0
numflock 9 10 200 232 0
numpty 1 1 64 64 0
numsiginfo 0 1 512 512 0
tcpsndbuf 290680 281736 4683256 6102456 0
tcprcvbuf 376832 445168 4683256 6102456 0
othersockbuf 45812 67316 1503232 4063232 0
dgramrcvbuf 0 700 240000 262144 0
numothersock 37 38 382 382 0
dcachesize 0 0 2194304 2317184 0
numfile 2617 2646 5432 5432 0
dummy 0 0 0 0 0
dummy 0 0 0 0 0
dummy 0 0 0 0 0
numiptent 54 54 128 128 0
mfg
druckgott
