Apache 2.4.18 - NodeJS Applikation per Proxy auf Port 80 erreichen
Verso
Hallo.
Und zwar habe ich auf meinem Virtual Private Server eine NodeJS Applikation auf Port 80 laufen, die ich über den Namen meiner Seite über Port 4000 erreichen kann. Logischerweise möchte ich natürlich "normal" auf die Seite zugreifen können, also per Port 80 und dies will ich gerne hinbekommen.
Wie sieht meine Datei unter /etc/apache2/sites-available/000-default.conf aus?
HTML:
<VirtualHost *:80>
    ServerAdmin blabla@gmail.com
    ServerName blabla-blabla.com
    ProxyPreserveHost On
    # setup the proxy
    <Proxy *>
        Order allow,deny
        Allow from all
    </Proxy>
    ProxyPass / http://localhost:4000/
    ProxyPassReverse / http://localhost:4000/
</VirtualHost>
Wie sieht meine vhost.conf (also eigentlich httpd.conf) aus?
HTML:
NameVirtualHost *:80
<VirtualHost *:80>
    redirect / http://blabla-blabla.com:4000/
</VirtualHost>
Wie sieht meine Datei unter /etc/apache2/apache2.conf aus?
HTML:
# This is the main Apache server configuration file.  It contains the
# See http://httpd.apache.org/docs/2.4/ for detailed information about
# the directives and /usr/share/doc/apache2/README.Debian about Debian specific
# hints.
# Summary of how the Apache 2 configuration works in Debian:
# The Apache 2 web server configuration in Debian is quite different to
# upstream's suggested way to configure the web server. This is because Debian's
# default Apache2 installation attempts to make adding and removing modules,
# virtual hosts, and extra configuration directives as flexible as possible, in
# order to make automating the changes and administering the server as easy as
# possible.
# It is split into several files forming the configuration hierarchy outlined
# below, all located in the /etc/apache2/ directory:
#	/etc/apache2/
#	|-- apache2.conf
#	|	`--  ports.conf
#	|-- mods-enabled
#	|	|-- *.load
#	|	`-- *.conf
#	|-- conf-enabled
#	|	`-- *.conf
# 	`-- sites-enabled
#	 	`-- *.conf
# * apache2.conf is the main configuration file (this file). It puts the pieces
#   together by including all remaining configuration files when starting up the
#   web server.
# * ports.conf is always included from the main configuration file. It is
#   supposed to determine listening ports for incoming connections which can be
#   customized anytime.
# * Configuration files in the mods-enabled/, conf-enabled/ and sites-enabled/
#   directories contain particular configuration snippets which manage modules,
#   global configuration fragments, or virtual host configurations,
#   respectively.
#   They are activated by symlinking available configuration files from their
#   respective *-available/ counterparts. These should be managed by using our
#   helpers a2enmod/a2dismod, a2ensite/a2dissite and a2enconf/a2disconf. See
#   their respective man pages for detailed information.
# * The binary is called apache2. Due to the use of environment variables, in
#   the default configuration, apache2 needs to be started/stopped with
#   /etc/init.d/apache2 or apache2ctl. Calling /usr/bin/apache2 directly will not
#   work with the default configuration.
# Global configuration
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE!  If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the Mutex documentation (available
# at <URL:http://httpd.apache.org/docs/2.4/mod/core.html#mutex>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
Mutex file:${APACHE_LOCK_DIR} default
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 5
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# logged here.  If you *do* define an error logfile for a <VirtualHost>
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the severity of messages logged to the error_log.
# Available values: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the log level for particular modules, e.g.
# "LogLevel info ssl:warn"
LogLevel warn
# Include module configuration:
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
# Include list of ports to listen on
Include ports.conf
# Sets the default security model of the Apache2 HTTPD server. It does
# not allow access to the root filesystem outside of /usr/share and /var/www.
# The former is used by web applications packaged in Debian,
# the latter may be used for local directories served by the web server. If
# your system is serving content from a sub-directory in /srv you must allow
# access here, or in any related virtual host.
<Directory />
	Options FollowSymLinks
	AllowOverride None
	Require all denied
</Directory>
<Directory /usr/share>
	AllowOverride None
	Require all granted
</Directory>
<Directory /var/www/>
	Options Indexes FollowSymLinks
	AllowOverride None
	Require all granted
</Directory>
#<Directory /srv/>
#	Options Indexes FollowSymLinks
#	AllowOverride None
#	Require all granted
#</Directory>
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives.  See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<FilesMatch "^\.ht">
	Require all denied
</FilesMatch>
# The following directives define some format nicknames for use with
# a CustomLog directive.
# These deviate from the Common Log Format definitions in that they use %O
# (the actual bytes sent including headers) instead of %b (the size of the
# requested file), because the latter makes it impossible to detect partial
# requests.
# Note that the use of %{X-Forwarded-For}i instead of %h is not recommended.
# Use mod_remoteip instead.
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
IncludeOptional conf-enabled/*.conf
# Include the virtual host configurations:
IncludeOptional sites-enabled/*.conf
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
GracefulShutDownTimeout 3
AddOutputFilter INCLUDES .shtml
AddType text/html .shtml
AddType application/x-httpd-php .php
AddType application/x-httpd-php-source .phps
Hat jemand Rat?
Sorry, aber wieviele Threads willst du jetzt noch zu deinem Problem eröffnen?
Das ist jetzt der dritte Thread dazu, daß du deine NodeJS-Applikation nicht zum Laufen bekommst und es ist weder für Helfende noch für den Hilfesuchenden sinnvoll, dasselbe Thema in drei unterschiedlichen Threads zu diskutieren.
Es wäre sinnvoller, wenn du entweder a) dich in die Konfiguration deines Webservers gründlich einarbeitest (Doku's dazu findet man reichlich im Netz) oder b) einen Dienstleister beauftragst, sich um die Bereitstellung der Webservices zu kümmern, so daß du dich auf dein Kerngeschäft (deine Applikation) konzentrieren kannst.
Hi, das möchte ich mal erläutern.
Es hat mehrdimensionale Gründe:
-Es erspart Helfenden und anderen Hilfesuchenden das unnötig lange springen in Threads, da Threads schnell unübersichtlich werden, bei zuviel Posts
-Abgesehen davon habe ich ganz unterschiedliche Probleme gehabt (NodeJS, DNS, Apache).
-Wofür gibt es bitte Threadkategorien? Wenn Du nur eine Sekunde nachdenkst, sollte Dir doch klar sein, dass es sonst nur eine Kategorie geben müsste in der jede Person einen Thread aufmacht und dort alle Probleme beschreibt, die er / sie hat.
Deine Antwort kann ich leider in keiner Weise nachvollziehen.
An dieser Stelle möchte ich auch auf die AGB des Forum verweisen, da heißt es:
"Beim Verfassen von Beiträgen ist unbedingt auf die Lesbarkeit und Verständlichkeit zu achten."
Und genau das mache ich, ich erhöhe die Verständlichkeit in dem ich die Probleme aufteile in unterschiedliche Threads.
Ein Thread in dem in einem Post ein Problem A beschrieben wird und im nächsten Post B ein Log von einem ganz anderen Problem - das verwirrt nur und ist kein Indiz für Verständlichkeit.
